SD opened Command connected 220 Microsoft FTP Service 331 Password required 530 User cannot log in. 221 Goodbye. Выдает ошибку, кто как решал скетч взял этот Настраивал фпт через диспетчер llS Спойлер: Код Код (C++): #include <SD.h> #include <SPI.h> #include <Ethernet.h> // comment out next line to write to SD from FTP server #define FTPWRITE // this must be unique byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x59, 0x67 }; // change to your network settings IPAddress ip( 192, 168, 2, 2 ); IPAddress gateway( 192, 168, 2, 1 ); IPAddress subnet( 255, 255, 255, 0 ); // change to your server IPAddress server( 1, 2, 3, 4 ); EthernetClient client; EthernetClient dclient; char outBuf[128]; char outCount; // change fileName to your file (8.3 format!) char fileName[13] = "test.txt"; void setup() { Serial.begin(9600); digitalWrite(10,HIGH); if(SD.begin(4) == 0) { Serial.println(F("SD init fail")); } Ethernet.begin(mac, ip, gateway, gateway, subnet); digitalWrite(10,HIGH); delay(2000); Serial.println(F("Ready. Press f or r")); } void loop() { byte inChar; inChar = Serial.read(); if(inChar == 'f') { if(doFTP()) Serial.println(F("FTP OK")); else Serial.println(F("FTP FAIL")); } if(inChar == 'r') { readSD(); } } File fh; byte doFTP() { #ifdef FTPWRITE fh = SD.open(fileName,FILE_READ); #else SD.remove(fileName); fh = SD.open(fileName,FILE_WRITE); #endif if(!fh) { Serial.println(F("SD open fail")); return 0; } #ifndef FTPWRITE if(!fh.seek(0)) { Serial.println(F("Rewind fail")); fh.close(); return 0; } #endif Serial.println(F("SD opened")); if (client.connect(server,21)) { Serial.println(F("Command connected")); } else { fh.close(); Serial.println(F("Command connection failed")); return 0; } if(!eRcv()) return 0; client.println(F("USER myuser")); if(!eRcv()) return 0; client.println(F("PASS mypassword")); if(!eRcv()) return 0; client.println(F("SYST")); if(!eRcv()) return 0; client.println(F("Type I")); if(!eRcv()) return 0; client.println(F("PASV")); if(!eRcv()) return 0; char *tStr = strtok(outBuf,"(,"); int array_pasv[6]; for ( int i = 0; i < 6; i++) { tStr = strtok(NULL,"(,"); array_pasv[i] = atoi(tStr); if(tStr == NULL) { Serial.println(F("Bad PASV Answer")); } } unsigned int hiPort,loPort; hiPort = array_pasv[4] << 8; loPort = array_pasv[5] & 255; Serial.print(F("Data port: ")); hiPort = hiPort | loPort; Serial.println(hiPort); if (dclient.connect(server,hiPort)) { Serial.println(F("Data connected")); } else { Serial.println(F("Data connection failed")); client.stop(); fh.close(); return 0; } #ifdef FTPWRITE client.print(F("STOR ")); client.println(fileName); #else client.print(F("RETR ")); client.println(fileName); #endif if(!eRcv()) { dclient.stop(); return 0; } #ifdef FTPWRITE Serial.println(F("Writing")); byte clientBuf[64]; int clientCount = 0; while(fh.available()) { clientBuf[clientCount] = fh.read(); clientCount++; if(clientCount > 63) { dclient.write(clientBuf,64); clientCount = 0; } } if(clientCount > 0) dclient.write(clientBuf,clientCount); #else while(dclient.connected()) { while(dclient.available()) { char c = dclient.read(); fh.write(c); Serial.write(c); } } #endif dclient.stop(); Serial.println(F("Data disconnected")); if(!eRcv()) return 0; client.println(F("QUIT")); if(!eRcv()) return 0; client.stop(); Serial.println(F("Command disconnected")); fh.close(); Serial.println(F("SD closed")); return 1; } byte eRcv() { byte respCode; byte thisByte; while(!client.available()) delay(1); respCode = client.peek(); outCount = 0; while(client.available()) { thisByte = client.read(); Serial.write(thisByte); if(outCount < 127) { outBuf[outCount] = thisByte; outCount++; outBuf[outCount] = 0; } } if(respCode >= '4') { efail(); return 0; } return 1; } void efail() { byte thisByte = 0; client.println(F("QUIT")); while(!client.available()) delay(1); while(client.available()) { thisByte = client.read(); Serial.write(thisByte); } client.stop(); Serial.println(F("Command disconnected")); fh.close(); Serial.println(F("SD closed")); } void readSD() { fh = SD.open(fileName,FILE_READ); if(!fh) { Serial.println(F("SD open fail")); return; } while(fh.available()) { Serial.write(fh.read()); } fh.close(); }
Получилось войти 227 Entering Passive Mode (ip). Data port: dataport Data connection failed FTP FAIL Все создается все портится, но когда он просит ответ с помощью PASV он выдает ошибку
Что, прям так и выдается строка "dataport" вместо номера порта - целого числа? - если да. то у вас в МК не тот скетч, который вы привели в первом сообщении, разбирайтесь
Код (C++): Ready. Press f or r SD opened Command connected 220 Microsoft FTP Service 331 Anonymous access allowed, send identity (e-mail name) as password. 230 User logged in. 215 Windows_NT 200 Type set to I. 227 Entering Passive Mode (192,168,19,151,221,148). Data port: 56724 Data connection failed FTP FAIL
