Передатчик отправляет. Но не понятно почему приемник не получает. Провода подключил А - А, В -В . Все перепроверил. Косяк где то в программе. Код (C++): // RS485, слейв. #include "CyberLib.h" #define DIR 11 // DE RE переключатель прием\передача uint32_t myTimer1=0, myTimer2=0; int i=0,k=0; int n[3]; uint8_t news[3]; uint8_t old[3]; uint8_t ID = 2; uint8_t Send[5]; static const uint8_t PROGMEM dscrc_table[] = { 0, 94,188,226, 97, 63,221,131,194,156,126, 32,163,253, 31, 65, 157,195, 33,127,252,162, 64, 30, 95, 1,227,189, 62, 96,130,220, 35,125,159,193, 66, 28,254,160,225,191, 93, 3,128,222, 60, 98, 190,224, 2, 92,223,129, 99, 61,124, 34,192,158, 29, 67,161,255, 70, 24,250,164, 39,121,155,197,132,218, 56,102,229,187, 89, 7, 219,133,103, 57,186,228, 6, 88, 25, 71,165,251,120, 38,196,154, 101, 59,217,135, 4, 90,184,230,167,249, 27, 69,198,152,122, 36, 248,166, 68, 26,153,199, 37,123, 58,100,134,216, 91, 5,231,185, 140,210, 48,110,237,179, 81, 15, 78, 16,242,172, 47,113,147,205, 17, 79,173,243,112, 46,204,146,211,141,111, 49,178,236, 14, 80, 175,241, 19, 77,206,144,114, 44,109, 51,209,143, 12, 82,176,238, 50,108,142,208, 83, 13,239,177,240,174, 76, 18,145,207, 45,115, 202,148,118, 40,171,245, 23, 73, 8, 86,180,234,105, 55,213,139, 87, 9,235,181, 54,104,138,212,149,203, 41,119,244,170, 72, 22, 233,183, 85, 11,136,214, 52,106, 43,117,151,201, 74, 20,246,168, 116, 42,200,150, 21, 75,169,247,182,232, 10, 84,215,137,107, 53}; // uint8_t crc8(const uint8_t *addr, uint8_t len) { uint8_t crc = 0; while (len--) { crc = pgm_read_byte(dscrc_table + (crc ^ *addr++)); } return crc; } void setup() { Serial.begin(9600); //открыть порт pinMode(DIR, OUTPUT); pinMode(7, INPUT); pinMode(8, INPUT); pinMode(9, INPUT); } void loop() { if (micros() - myTimer1 >= 1000) { // таймер на 1000 мкс myTimer1 = micros(); // сброс таймера news[0]=digitalRead(7); news[1]=digitalRead(8); news[2]=digitalRead(9); if (old[0] != news[0] ) {n[0]++; old[0]=news[0] ;} if (old[1] != news[1] ) {n[1]++; old[1]=news[1] ;} if (old[2] != news[2] ) {n[2]++; old[2]=news[2] ;} } if (millis() - myTimer2 >= 1000) { // таймер на 1 с myTimer2 = millis(); // сброс таймера if (true) { // заполняем массив n[0]=i/100; n[1]=i/100+20; n[2]=i/150; Send[0] = ID; Send[1] = n[0]; Send[2] = n[1]; Send[3] = n[2]; Send[4] = crc8((uint8_t*)&Send, sizeof(Send) - 1); // контрольная сумма // отправляем // включаем передачу D11_High; Serial.write(Send[0]); Serial.write(Send[1]); Serial.write(Send[2]); Serial.write(Send[3]); Serial.write(Send[4]); D11_Low; } Serial.println(i); Serial.println(n[0]); Serial.println(n[1]); Serial.println(n[2]); i=0; } i++; if (i==500) {digitalWrite(13, !digitalRead(13));} } Приемник: #define DIR 2 const byte ID = 2; uint8_t val[4]; void setup() { Serial.begin(9600); //открыть порт pinMode(DIR, OUTPUT); digitalWrite(DIR, LOW); // включаем прием } void loop() { if (Serial.available()) { Serial.println("y"); byte id = Serial.read(); // читаем первый байт, в нем для кого этот пакет if (id == ID){ // и если пакет пришел нам val[0] = Serial.read(); val[1] = Serial.read(); val[2] = Serial.read(); val[3] = Serial.read(); } else Serial.println("no"); } }
