Нужен перевод с C++ на JS.
Тема в разделе "Iskra JS, Espruino, Йодо", создана пользователем shoom, 7 фев 2018.
  1. shoom
    shoom Нуб
    #include "QuadDisplay2.h"
    #define POMP_PIN        4
    #define HUMIDITY_PIN    A0
    #define HUMIDITY_MIN    200
    #define HUMIDITY_MAX    700
    #define INTERVAL        60000 * 3
    unsigned int humidity = 0;
    unsigned long waitTime = 0;
    QuadDisplay qd(9);
    void setup(void)
    qd.begin();
    pinMode(POMP_PIN, OUTPUT);
    qd.displayInt(0);
    void loop(void)
    int humidityNow = analogRead(HUMIDITY_PIN);
      if(humidityNow != humidity) {
        humidity= humidityNow;
        qd.displayInt(humidityNow);
      if ((waitTime == 0 || millis() - waitTime > INTERVAL) && humidity < HUMIDITY_MIN ) {
        digitalWrite(POMP_PIN, HIGH);
       delay(2000);
        digitalWrite(POMP_PIN, LOW);
       waitTime = millis();
  2. Yaroslav1
    Yaroslav1 Нерд
    Код (Javascript):
    var SYMBOLS = {
      ' ': 255, '-': 127, '^': 253, '_': 239, '*': 57, '0': 129, '1': 243,
      '2': 73, '3': 97, '4': 51, '5': 37, '6': 5, '7': 241, '8': 1,
      '9': 33, 'A': 17, 'a': 65, 'B': 1, 'b': 7, 'C': 141, 'c': 79,
      'D': 67, 'd': 67, 'E': 13, 'e': 13, 'F': 29, 'f': 29, 'G': 133,
      'g': 133, 'H': 19, 'h': 23, 'I': 243, 'i': 243, 'J': 227, 'j': 227,
      'K': 19, 'k': 23, 'L': 143, 'l': 143, 'M': 13, 'm': 13, 'N': 87,
      'n': 87, 'O': 129, 'o': 71, 'P': 25, 'p': 25, 'Q': 49, 'q': 49,
      'R': 95, 'r': 95, 'S': 37, 's': 37, 'T': 15, 't': 15, 'U': 131,
      'u': 199, 'V': 131, 'v': 199, 'W': 131, 'w': 199, 'X': 19, 'x': 23,
      'Y': 35, 'y': 35, 'Z': 73, 'z': 73, '.': 254
    var QuadDisplay = function(opts) {
      if (typeof opts === 'number') {
        SPI2.setup({mosi: B15, miso: B14, sck: B13});
        this._spi = SPI2;
        this._cs = opts;
        this._cs.mode('output');
      } else {
        opts = opts || {};
        this._spi = opts.spi;
        this._cs = opts.cs;
      this._intervalID = null;
      this._shift = 0;
      this.display('    ');
    QuadDisplay.prototype.display = function(str, alignRight) {
      alignRight = alignRight || false;
      var s = str.toString();
      this._data = [];
      for (var i = 0, d = -1; i < s.length; i++) {
        if (s[i] !== '.') {
          d++;
          this._data[d] = SYMBOLS[s[i]];
        } else {
          // prevent dot-dot and space-dot collapsing
          if (d !== -1 && (this._data[d] !== 0xFE && this._data[d] !== 0xFF)) {
            this._data[d] &= 0xFE;
          } else {
            d++;
            this._data[d] = SYMBOLS['.'];
      if (alignRight) {
        if (this._data.length < 4) {
          this._data = new Array(4 - this._data.length).fill(SYMBOLS[' '], 0).concat(this._data);
        this.frame(this._data.length - 4);
      } else {
          this._data = this._data.concat(new Array(4 - this._data.length).fill(SYMBOLS[' '], 0));
        this.frame(0);
    QuadDisplay.prototype.marquee = function(str, period) {
      period = period || 300;
      if (this._intervalID) {
        this._intervalID = clearInterval(this._intervalID);
        this._shift = 0;
      this.display('   '+str+'   ', false);
      var self = this;
      this._intervalID = setInterval(function() {
        self._shift++;
        if (self._shift > self._data.length - 4) {
          self._shift = 0;
        self.frame.call(self, self._shift);
      }, period);
    QuadDisplay.prototype.frame = function(shift) {
      this._shift = shift;
      if (this._shift < 0) {
        this._shift = 0;
      if (this._shift > this._data.length - 4) {
        this._shift = this._data.length;
      this._spi.send(this._data.slice(this._shift, this._shift + 4), this._cs);
      digitalWrite(this._cs,0);
    QuadDisplay.prototype.displayInt = function(int, err, bl, inter) {
      err = err || false;
      bl = bl || false;
      inter = inter || 1000;
      var str = "";
      if (int > 9 && int < 100) {
        str = "  " + int;
      } else if (int > 99 && int < 1000) {
        str = " " + int;
      } else if (int > 999 && int < 10000) {
        str = "" + int;
      } else if (int > -1 && int < 10) {
        str = "   " + int;
      } else {
        if (err) {
          this.display("Err");
        if (bl) {
          setTimeout(function() {
            this.display("    ");
          }, inter);
        return false;
      this.display(str);
      return true;
    function connect(opts) {
      return new QuadDisplay(opts);
    var humidity = 0;
    var waitTime = 0;
    var qd = connect(9);
    qd.displayInt(0);
      var humidityNow = analogRead(A0);
      if ((waitTime === 0 || getTime() - waitTime > (60 * 3)) && humidity < 200) {
        digitalWrite(P4, 1);
          digitalWrite(P4, 0);
        }, 2000)
        waitTime = getTime();
    }, 0);
