Есть такое и комп с Ubuntu. Arduino IDE работает нормально, док станцию видит, но при попытке залить скеч (любой) выдаёт ошибку: Код (Text): In file included from /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSongData.cpp:24:0: /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSongData.h:31:52: error: variable ‘lrfSong’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’ extern LRFSoundStruct PROGMEM lrfSong[LRF_SONG_SIZE]; ^ /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSongData.cpp:26:45: error: variable ‘lrfSong’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’ LRFSoundStruct PROGMEM lrfSong[LRF_SONG_SIZE] = { ^
УМВР Можно попробовать добавит const перед LRFSoundStruct внутри LRFSongData.h:31 и LRFSongData.cpp:26
Теперь так... Код (Text): In file included from /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:24:0: /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.h:47:71: error: variable ‘lrfSignaturePatterns’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’ extern LRFPatternStruct PROGMEM lrfSignaturePatterns[LRF_SIGNATURE_MAX]; ^ /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.h:48:95: error: variable ‘lrfSignatureSounds’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’ extern LRFSoundStruct PROGMEM lrfSignatureSounds[LRF_SIGNATURE_MAX * LRF_SIGNATURE_SOUND_COUNT]; ^ /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:26:64: error: variable ‘lrfSignaturePatterns’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’ LRFPatternStruct PROGMEM lrfSignaturePatterns[LRF_SIGNATURE_MAX] = ^ /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:41:88: error: variable ‘lrfSignatureSounds’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’ LRFSoundStruct PROGMEM lrfSignatureSounds[LRF_SIGNATURE_MAX * LRF_SIGNATURE_SOUND_COUNT] = ^ /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFOctave’ [-fpermissive] }; ^ /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFIntonation’ [-fpermissive] /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFDuration’ [-fpermissive] /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFDuration’ [-fpermissive] /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFOctave’ [-fpermissive] /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFIntonation’ [-fpermissive] /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFDuration’ [-fpermissive] /home/alexey/sketchbook/libraries/LittleRobotFriends/LRFSignatureData.cpp:115:1: error: invalid conversion from ‘int’ to ‘LRFDuration’ [-fpermissive]
Ну опять, первая часть ошибок связана с пропуском const, а вторая с неявным приведением int к enum, что в общем случае действительно некорректно. Либо включайте -fpermissive, либо правьте код.
