Работает прямо на малине. Код (Text): J-Link>? Available commands are: Command name Command syntax Command function ---------------------- ? ? [<Command>] Show information about all or specific commands. Exit Exit Close J-Link connection and quit. ExitOnError EoE <1/0> Exit on error. Sleep Sleep <Delay> Waits the given time (in milliseconds). Log Log <filename> Enables log to file. ExpDevList ExpDevList <Filename> Export device names from DLL internal device list to text file. ExpDevListXML ExpDevListXML <Filename> Export device names from DLL internal device list to XML file. USB USB [<SN>] Connect to J-Link via USB. IP IP <IPAddr|RemoteServerString> Connect to J-Link via TCP/IP or to Remote Server. SelectProbe SelectProbe [<Interface0> <Interface1> ...] Show list of all connected probes via specified interface. The Probe to communicate with can then be selected. ShowEmuList ShowEmuList [<Interface0> <Interface1> ...] Show list of all connected probes via specified interface. Power Power <On|Off> [perm] Switch power supply for target. VTREF VTREF <Value[mV]>. 0 == Auto detection Set fixed value for VTref on J-Link. VCOM VCOM <enable|disable> Enable/disable VCOM. Takes effect after power cycle of the Probe. ShowFWInfo ShowFWInfo Show firmware info. ShowHWStatus ShowHWStatus Show hardware status. License License Show list of all available license commands. IPAddr IPAddr Show/Assign IP address and subnetmask of/to connected Probe. GWAddr GWAddr Show/Assign network gateway address of/to connected Probe. DNSAddr DNSAddr Show/Assign network DNS server address of/to connected Probe. ShowConf ShowConf Show configuration of the connected Probe. Calibrate Calibrate Calibrate the target current measurement. Connect Connect Connect to target device. Device Device <DeviceName> Select specific device J-Link shall connect to. SelectInterface SelectInterface <Interface> Select target interface. Speed Speed <freq|auto|adaptive> Set target interface speed. LE LE Change mode to little endian. BE BE Change mode to big endian. Halt Halt Halt CPU. IsHalted IsHalted Return current CPU state. WaitHalt WaitHalt [<TimeoutMs>] (default: 1000 ms) Wait until CPU is halted or timeout is reached. Go Go Start CPU if halted. Reset Reset Reset CPU. ResetX ResetX <DelayAfterReset> Reset CPU with delay after reset. RSetType RSetType <Type> Set the current reset type. Step Step [<NumSteps> (decimal)] (default is 1) Execute step(s) on the CPU. .... .... вырезал - много очень! .... Mem16 Mem16 [<Zone>:]<Addr>, <NumItems> (hex) Read 16-bit items. Mem32 Mem32 [<Zone>:]<Addr>, <NumItems> (hex) Read 32-bit items. Write1 W1 [<Zone>:]<Addr>, <Data> (hex) Write 8-bit items. Write2 W2 [<Zone>:]<Addr>, <Data> (hex) Write 16-bit items. Write4 W4 [<Zone>:]<Addr>, <Data> (hex) Write 32-bit items. JTAGConf JTAGConf <IRpre>, <DRpre> Set number of IR/DR bits before Target device. .... .... вырезал - много очень! .... TStart TStart TRACE - Start. TStop TStop TRACE - Stop. SWOSpeed SWOSpeed SWO - Show supported speeds. SWOStart SWOStart SWO - Start. SWOStop SWOStop SWO - Stop. SWOStat SWOStat SWO - Display SWO status. SWORead SWORead SWO - Read and display SWO data. SWOShow SWOShow SWO - Read and analyze SWO data. SWOFlush SWOFlush SWO - Flush data. SWOView SWOView SWO - View terminal data. Erase Erase [<SAddr>, <EAddr>] Erase flash (range) of selected device. LoadFile LoadFile <FileName>, [<Addr> (.bin only)]. Load data file into target memory. Supported ext.: *.bin, *.mot, *.hex, *.srec .... .... вырезал - много очень! .... TestRSpeed TestRSpeed [<Addr> [<Size>] [<NumBlocks>]] Measure upload speed from target memory. TestCSpeed TestCSpeed [<RAMAddr>] Measure CPU speed. TestNWSpeed TestNWSpeed [<NumBytes> [<NumReps>]] Measure network download speed. TestNRSpeed TestNRSpeed [<NumBytes> [<NumReps>]] Measure network upload speed. MR MR Measure RTCK react time. Clock Clock TCK - Clock. Clock00 Clock00 TCK - Clock with TDI = TMS = 0. ClrTCK ClrTCK TCK - Clear. SetTCK SetTCK TCK - Set. ClrTDI ClrTDI TDI - Clear. SetTDI SetTDI TDI - Set. ClrTMS ClrTMS TMS - Clear. SetTMS SetTMS TMS - Set. ClrTRST ClrTRST TRST - Clear. SetTRST SetTRST TRST - Set. ClrRESET ClrRESET RESET - Clear. SetRESET SetRESET RESET - Set. ---------------------- J-Link> ну ещё (уж больно много): Код (Text): J-Link>halt J-Link: ARM9 CP15 Settings changed: 50078 from 51078, MMU Off, ICache Off, DCache Off PC: (R15) = 00101104, CPSR = 60000093 (SVC mode, ARM IRQ dis.) Current: R0 =00008200, R1 =00000B00, R2 =00000040, R3 =001010D0 R4 =FFFA4000, R5 =00000002, R6 =00000000, R7 =003002DC R8 =00300F98, R9 =00000040, R10=00000013, R11=00000000, R12=003002DC R13=00300F7C, R14=001010F4, SPSR=00000010 USR: R8 =00300F98, R9 =00000040, R10=00000013, R11=00000000, R12=003002DC R13=B39CF7BD, R14=BBFE44AD FIQ: R8 =45F83C3F, R9 =FFFA0000, R10=FFFFF600, R11=FFFFF000, R12=00300300 R13=87A23E59, R14=9030A002, SPSR=00000010 IRQ: R13=10425B5A, R14=02842061, SPSR=00000010 SVC: R13=00300F7C, R14=001010F4, SPSR=00000010 ABT: R13=2508F2D2, R14=398BAC07, SPSR=00000010 UND: R13=73C00B05, R14=88C899B4, SPSR=00000010 J-Link> Код (Text): igor@Irpi4:~/coding/JLink_Linux_V754b_arm $ ./JLinkExe SEGGER J-Link Commander V7.54b (Compiled Sep 14 2021 16:15:59) DLL version V7.54b, compiled Sep 14 2021 16:15:43 Connecting to J-Link via USB...O.K. Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46 Hardware version: V8.00 S/N: 11111118 VTref=3.254V Type "connect" to establish a target connection, '?' for help J-Link>connect Please specify device / core. <Default>: AT91SAM9260 Type '?' for selection dialog Device> Одним словом работает прямо на малине 4. Вот только JFlash (он GUI) хочет активации, ну прямо как в Винде. Ну что же SEGGER он и есть SEGGER. https://www.segger.com/news/segger-j-link-adds-support-for-raspberry-pi-as-host/ http://hardlinux.ru/note/71301/ https://blog.feabhas.com/2019/07/using-a-raspberry-pi-as-a-remote-headless-j-link-server/ а это в довесок: http://www.cesareriva.com/install-segger-j-link-tools-on-gnulinux-x64-machine/ Скачал, установил... но как сервер не испытал. Правда искал конфигурацию JLink для openocd. Испытал - работает. Осталось придумать как к codeblocks всё это прикрутить. А может Keil uVision на малине бывает?
Да кто его знает... я просто искал J-Link и желательно для opencd, а вот наткнулся. И он работает. Железка J-Link под рукой, испытал и работает! Даже JLink.exe там называется JLinkExe, но функционал выше и добавлены чипы в списке. Одно только, никогда не юзал JLink(программу) в пакетном режиме. Вот бы её в BASH закрутить с интерфейсом с этим самым BASH. Как демона запускать что ли? Или он JLinkExe сам "перваривает" скрипты для него? Тогда надо курить! Опять курить?! Выгоднее наверное opencd курить - окурков меньше, да и не одновременно всё курить трудно... уж больно много всё сразу.
