W5500 + udp
Тема в разделе "Arduino & Shields", создана пользователем Михаил123, 19 июл 2022.
  1. небольшой код, из примера библиотеки w5500.h, приведенный ниже, не получает пакеты.
    какие есть варианты?
    #include <SPI.h>
    #include <Ethernet_W5500.h>
    #include <EthernetUDP.h>
    // Enter a MAC address for your controller below.
    // Newer Ethernet shields have a MAC address printed on a sticker on the shield
    #if defined(WIZ550io_WITH_MACADDRESS) // Use assigned MAC address of WIZ550io
    #else
    byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
    #endif
    unsigned int localPort = 8888;      // local port to listen for UDP packets
    IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server
    // IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server
    // IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
    const int NTP_PACKET_SIZE= 48; // NTP time stamp is in the first 48 bytes of the message
    byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
    // A UDP instance to let us send and receive packets over UDP
    EthernetUDP Udp;
    unsigned long sendNTPpacket(IPAddress&); // prototype
    // Open serial communications and wait for port to open:
       while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      // start Ethernet and UDP
      if (Ethernet.begin() == 0) {
    #else
      if (Ethernet.begin(mac) == 0) {
    #endif
        Serial.println("Failed to configure Ethernet using DHCP");
        // no point in carrying on, so do nothing forevermore:
        for(;;)
      Udp.begin(localPort);
      sendNTPpacket(timeServer); // send an NTP packet to a time server
        // wait to see if a reply is available
      delay(1000);
      if ( Udp.parsePacket() ) {
